I set up this simple model (symmetrical panel with uniform load and simply supported beam) and I run it.
Instability problem (as it was expected) occurred but what else could I do? I disregard it.
So far, so good. Untill somebody is taking a look a at the panel deformations.
Panel is twisting right.
(I know that I can turn the supports into fixed and add pinned releases in beam to bypass the problem but instability type 3 happens quite often and I'm not sure that finally this is a trivial problem)
Add the RY restrain at either of supports to prevent the rotation of the model about the global Y axis as indicated in the instability warning.
