Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Shifting Nodes & Displaying XYZ Coordinates
5 REPLIES 5
460 Views, 5 Replies
I am converting from another structural platforms so I'm unfamiliar with with Robot's capabilites limitations.
These may seem like very simple but please can you answer the following questions.
- How do I shift an individual node by a certain amount in the XY or Z direction?
- Is it possible to visually display the X,Y,Z coordinates next the node? Helpful when determining the straightness of a column or working out why a panel isn't possible.
- Is it possible to highlight several nodes and shift all a specified amount in the X,Y or Z direction?
- I would like to have a beam start a certain dimension from the top of the column. Apart from inserting a new node is there an easier way to do this?
Your help would much appreciated.
Richard
5 REPLIES 5
Rafal.Gaweda
Rafal Gaweda
Rafal.Gaweda
No.
You can check coordinates
- mouse over node - in Robot status bar
- right hand mouse menu (click on node) and select Object Properties
Rafal Gaweda
Rafal.Gaweda
Yes. Make selection \ mutiselection and use Translate option (shown above)
Rafal Gaweda
Rafal.Gaweda
Insert new node by Division option (set data then click near top end of bar ; it works on selection also but it such case distance is considered from start node of bar(s)):
Rafal Gaweda
in reply to: Rafal.Gaweda
Thank you
