Hello.
I'm fairly new to ROBOT SA and I would like to model a structure that's really similar to the attached image, only that I would like to model it as a shell and not as a solid! But the only problem that i've encountered so far is creating the opening in the shell model. I've tried to do an object combination but i honestly can't get it working with shells!
I've tried to do with solids but the model gets a llittle heavy, so therefore i would like to avoid that.
Any ideas?
Thank you!
@ziegler123 Artur Kosakowski edited the topic for better findability
Solved by Rafal.Gaweda. Go to Solution.
Hello! Is this function gone in 2019? I only see Operand A and B, I have no possibility of changing the face-settings down in the shown picture.
