Discussion Groups
Robot Structural Analysis
Active Contributor
ziegler123
Shell problem - opening
714 Views, 16 Replies
02-18-2013 04:23 AM
Hello.
I'm fairly new to ROBOT SA and I would like to model a structure that's really similar to the attached image, only that I would like to model it as a shell and not as a solid! But the only problem that i've encountered so far is creating the opening in the shell model. I've tried to do an object combination but i honestly can't get it working with shells!
I've tried to do with solids but the model gets a llittle heavy, so therefore i would like to avoid that.
Any ideas?
Thank you!
Please use plain text.
Active Contributor
ziegler123
Re: Shell problem - opening
02-19-2013 03:05 AM in reply to: ziegler123
so.. any ideas?
Product Support
Rafal.Gaweda
02-19-2013 03:17 AM in reply to: ziegler123
It can be done but unfortunatelly it is not painless.
I will try to show you how to do it tomorrow.
Rafal Gaweda
Active Contributor
ziegler123
02-19-2013 03:21 AM in reply to: Rafal.Gaweda
Thank you so much! I will be expecting your response tomorrow then.
Product Support
Rafal.Gaweda
02-21-2013 04:48 AM in reply to: ziegler123
Example with 2 cylinders
Rafal Gaweda
Active Contributor
ziegler123
02-21-2013 09:59 AM in reply to: Rafal.Gaweda
Yes, that's it! I did try to do a boolean operation but never expected that you had to turn off the Solid Modeler! Thank you so much!
Active Member
susi33
03-27-2014 09:13 AM in reply to: Rafal.Gaweda
I tried as you shown in this instruction, but this didn't work. After object combinations my cylinder looks like deformed and when i press button to create mesh, hole dissappears. I have no idea what is wrong.
Active Member
susi33
03-27-2014 09:58 AM in reply to: Rafal.Gaweda
And this is image like it looks like after meshing
Product Support
Artur.Kosakowski
03-28-2014 04:09 AM in reply to: susi33
As there is no surface elements generated inside the 'circle' it means you actually have got the opening there. You can see that after switching off the display of the panel interior as on the picture attached by Rafał (the last object on the right hand side).
Artur Kosakowski
Active Member
susi33
03-28-2014 05:32 AM in reply to: Artur.Kosakowski
Ok, but there is problem when i want to aplly a load. It seems like load is applied to this "hole".  Please look at my image. I modeled another panel to compare proper opnening with load with my cylinder opening.
