Hi, after the calculate the provided reinforcement for the walls, the updated reinforcement didn't export on revit ??
And
when the revit model exported to robot the spread foundation dimension different from the original model , what is the problem???
Regard
Solved by Rafal.Gaweda. Go to Solution.
There is not option:
Take a look below:
