Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
shear stress , Vu
20 REPLIES 20
Message 1 of 21
egoze
2267 Views, 20 Replies
shear stress , Vu
hi sir
i have a problem with shear stress for punching
the problem is
when i read the shear stress in robot  give me strange values
i have done manual calcolation punching for internal l column
fc=25 mpa ,fy=420 mpa, cover =25mm, thikness=250mm
c1,c2=50cm
pu=1025 kn
Mux=35kn.m
Muy=35kn.m
b0=2.9
jc=0.0585 m^4
Vu max aplied shear = 1.744 mpa
sir i want to read the Vu from robot how -
see attachments please
20 REPLIES 20
Message 2 of 21
egoze
in reply to: egoze
im looking to hear from you
Message 3 of 21
chrismcc
in reply to: egoze
Assuming you have parameter set to middle, the values of shear stress you are seeing are 1.5 x the average shear for a rectangular section, so your 1.744 (average) would show up as 2.62 at the middle of the rectangular cross section and 0 at the upper and lower.  Try it on a simple span beam to verify.
Hope this helps a  little.
Regards
Chris
Message 4 of 21
egoze
in reply to: egoze
thank you chrismcc  for help.
Dear sir  Rafal
im really confused for reading shear stress in robot
i attach the manaul hand calcolution for punching
and i tryed to take the Reduse forces above the column and wall  but still not close to 1.744mpa it was 1.37mpa
see attachment please
Message 5 of 21
egoze
in reply to: egoze
hellooo
good mourning sir
would you please tell me why you did not answer my question up to now   🙂
Message 6 of 21
Rafal.Gaweda
in reply to: egoze
It seems you have forgotten that shear force diagram across FE thickness is parabolic
So average value is 2/3 of given by Robot -> 2,93 on map-> 1,953 - close enough to your hand calcs
Rafal Gaweda
Message 7 of 21
egoze
in reply to: Rafal.Gaweda
thank you sir  for reply
sir is this facotre (2/3) i mean working for  corner column and edge as well ?
and why you didnt read 3.27 instead of  2.93 ?
i wish to know please
Again thank in advance
egoze
Message 8 of 21
Rafal.Gaweda
in reply to: egoze
I took middle value
Rafal Gaweda
Message 9 of 21
chrismcc
2/3 factor applies to rectangular sections.
Sent from Samsung Mobile
Message 10 of 21
egoze
helooo sir
i have done corner column for the same modle ,and i rearange the corner column in slab to conseder it as a corner .as you know sometimes the robot coseder it as an edge column
i have read the stress at the face of column  in robot are was 3.86  and 1.5 mpa
the average (as you said )=2.68 mpa
2/3*2.68=1.78mpa
good for maunual calco=1.86 mpa
my question   WHEN YOU DO CHECK PUNCHING BY THE PROGRAM
  Q(KN) IS VERY VERY LARGE ?????
YOU CAN SEE THE ATTACHMENTS
Message 11 of 21
egoze
**************new
hello sir
i have read the stress at the face of column  in robot are was 3.86  and 2.56 mpa
the average (as you said )=3.21 mpa
2/3*3.21=2.14mpa
 for maunual calco
force=205 kn
m1 =105kn.m
m2=86kn.m
b1=b2=c1+d/2=0.5+0.217/2=0.6085
bo=1.217
Jc=0.016
Vu=0.776+0.759+0.622
Vu= 2.159mpa max stress
  Q(KN) IS VERY VERY LARGE ?????    what is the furmula of Q(KN)
have a look for new pic please
Message 12 of 21
egoze
and at wich loud combination the program check punching ?
Message 13 of 21
dimogrec
in reply to: egoze
egoze perhaps this page will help and also download the verification manual for EU codes from here (dropbox). (If the downloaded file isn't shown properly just add-type    .pdf   after the name of the file)
Message 14 of 21
Rafal.Gaweda
in reply to: dimogrec
Good link.
In short : moments are also considered in punching check ; Q and Qadm are calculated reducing set of forces to axial force only (giving the same punching like initial axial force and moments)
Rafal Gaweda
Message 15 of 21
egoze
thank you dimogrec
i hope to solve this problem
i m waiting Mr Rafal for reply
Message 16 of 21
Rafal.Gaweda
in reply to: egoze
data used for calculations in Robot:
Support no. / Point: S4
V = 205.98 (kN)
Mx = 87.07 (kN*m)
My = -105.58 (kN*m)
A = 0.27 (m2)
gammax = 0.40
gammay = 0.40
Cmaxx = 0.15
Cmaxy = 0.46
Cminx = -0.46
Cminy = -0.15
Jx = 1094456.9 (cm4)
Jy = 1094456.9 (cm4)
betac = 1.00
alfa = 1.00
alfas = 30.00
fi= 0.75
S1 = 6.00
heff = 22.0 (cm)
vlim = 1.25 (MPa)
v = 3.99 (MPa)
A = 0.27 (m2)
Rafal Gaweda
Message 17 of 21
egoze
Smiley Happy Thank you sir
a small point can i find this (data used for calculations in Robot)  as you did
for anther columns
how can i got this data used for calcolation
Message 18 of 21
Rafal.Gaweda
in reply to: egoze
In 2015 you can not get this data
Rafal Gaweda
Message 19 of 21
egoze
i have version 2014 and 2015
Message 20 of 21
Rafal.Gaweda
in reply to: egoze
This is all I can tell you right now.
Rafal Gaweda
