Hi there,
By default, frame element forces and deformations are calculated without shear deformations considered. Is there an option which I can set Robot to take shear deformations into account "for all members"? One can set this option for any given member trough Geometry > Additional Attributes > Advanced Bar Properties. I want to learn if there is a global option that will set this property "on" for all type of elements. Thanks
Solved by Artur.Kosakowski. Go to Solution.
There is no global setting but typing all in the list field in the dialog you refer to will do the job. Mind to do this after you have all bar elements defined.
