Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 9
byron86
1378 Views, 8 Replies
Shear Area
I have a custom angle section,  how is robot determining the shear areas?
according to BS5950,  its the longest leg of concerns area*0.9.  So im confused how its getting its values. Secondly, why is there an alpha value.
8 REPLIES 8
Message 2 of 9
byron86
in reply to: byron86
Ag the units confused me.  So its determined the principal axis but again how does it calculate the shear areas for the orientated axis?
Message 3 of 9
Artur.Kosakowski
By integration of shear stresses.
Artur Kosakowski
Message 4 of 9
byron86
in reply to: Artur.Kosakowski
okay is there a way to check this?
Message 5 of 9
Artur.Kosakowski
1. Apply a shear force in the given direction
2. Check stress distribution in a cross section (stress analysis map)
3. " Slice a profile into straps perpendicular to the direction of shear force and assume values of stress for each of them
4. Sum up such obtained stresses and divide by applied shear force
In general the steel design module calculates shear areas on its own following the selected design code provisions.
Artur Kosakowski
Message 6 of 9
byron86
So just to confirm.  You determine an average stress for the entire profile.  then Force/(average Stress)= Shear Area
Okay thanks, its trickey for angles but the code would just take each leg parallel to the direction and use just that area, however due to alpha angle I guess distributes more stress and creates a greater shear area.
Message 7 of 9
Artur.Kosakowski
Artur Kosakowski
Message 8 of 9
Could you tell me what the letters mean? Is Q the first moment of area? If so, in my case i have a symetric H-section, does that mean that it's only from half of the section? Is G the distortional module - 80 GPa right?
Message 9 of 9
Artur.Kosakowski
It is a shear force
Correct.
Artur Kosakowski
