When we use integration with RSA in 2103 Revit:
In 2012 version all worked properly.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Solved by Romanich. Go to Solution.
I have made quick tests and all seems to be OK. Could you send the Revit model and indicate what to select please?
Thank you, Artur. I understood what's wrong - I'm working with analytical model and selected a part only of analytical model , but properly to select phisical model.
Roman Zhelezniak
