Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Selecting particular ULS case from envelop results
8 REPLIES 8
Message 1 of 9
nany717
997 Views, 8 Replies
I am doing a reaction report for a structure. I am using RSA Professional 2014. I am new to this software. Earlier I used RISA 3D for structural analysis.
I have 6 pinned support nodes in the structure, and I have generated load combinations using automatic combination rules. In the results-> reactions , I checked the envelop reactions for the nodes.
Lets say, my support node numbers are from 1 to 6 and I got the envelop result for node 1 , FZ high in ULS/1234. Similarly I can see envelop reactions for other nodes as well, but none of the other support nodes gave envelop results for this case. I know this ULS case might not be critical for other nodes, so they haven't shown the results for this case.
What I want now is to check the reaction values at other nodes for that particular ULS/1234 case. I was unable to selec this single case.
I have attached a screenshot of the envelope reactions.
Please help, Thanks in advance.
8 REPLIES 8
Message 2 of 9
Artur.Kosakowski
in reply to: nany717
Switch to the Values tab and set ULS case in the load cases selection field.
Artur Kosakowski
Message 3 of 9
nany717
in reply to: Artur.Kosakowski
Hi Artur,
Thank you for the quick response.
Its giving all the components reaction values as you said, but i want to filter out certain cases and I want results for all the support nodes for these cases.
As shown in the picture, I want those highlighted cases for all the support nodes. I dont want to copy paste the values, instead I will be using the screenshots in my report. So I need all these nodes with these cases at one place.
Message 4 of 9
Artur.Kosakowski
In such case you should generate manual combinations instead of the automatic ones or convert the select components of code combinations.
Artur Kosakowski
Message 5 of 9
nany717
I am going with the second option (Code Combination --> Combination).
I really wished there will be a filter sort of thing for this issue. Bad Luck.
Anyway my problem is solved. Thanks Artur.
Message 6 of 9
t.sautierr
Is is not a filter but you can at least sort the combination even with automatic ones and then copy paste what you want easely.
Message 7 of 9
nany717
in reply to: t.sautierr
Yes, I can sort the combination, but I can't make the unwanted case components go away ( i mean hide them).
In my case I have lot of case components, 18000 approx ...but I need only 30 of them where I want to check the reactions on the support nodes.
Message 8 of 9
t.sautierr
then the simpliest is as artur told you bafore : manual comb (in automatic generator), and select only the comb number you want to be generated, or generate automatically and after create a simple load case from the component of ELU/ELS comb
Message 9 of 9
nany717
Yep, thats what saved me today...I was banging my head; thinking that there will be a filter...After straining my eyes a lot , I joined this form 🙂
