Dear support,
I have been studying the Tranining Manual (Metric Version), and I have one question about load case selection for Steel Design.
In some examples, when choosing the load case to analyse or for optimization of the profiles (see pages 32,73,165,168), load combination where never chosen. For example, if we see the results of the exercise on page 166, code group 5 has a result of 0,98. I believe, if we run again with any combination this profile wouldn't pass.
Am I missing something?
Gustavo
Solved by Artur.Kosakowski. Go to Solution.
I'd say that if you created combinations and used them for the design you would end up with larger sections found as the correct ones
The examples are intended to get you familiar with the steel design module rather than being the 'real' design cases but of course you are absolutely right that combinations are in most cases used to check the section capacity (rather than simple load cases).
