Hi guys,
I'm having trouble with some nodes. I want to select all pinned nodes, and view them in a new window.
I used special selection, and selected all the nodes with the pinned attribute.
Ok so far.
The problem is that in spite the fact they are selected, and i have the options "node numbers" and "display attributes only for selected objects" turned on, these nodes don't show up.
I've done this in other models but now it just doesn;t work.
Any ideas why?
I also noticed that if I select a bar on which these node are, the end nodes show up (the numbers and the pinned triangle symbol), while the ones in the middle of the bar don't.
Thanks in advance.
Solved by Artur.Kosakowski. Go to Solution.
What is the model type you have - is it a building? If yes check if you have story filter applied on the display.
