Discussion Groups
Robot Structural Analysis
Valued Contributor
MohammadZaman
Accepted Solution
Seismic Result
399 Views, 2 Replies
08-17-2011 12:50 PM
Hi
I think the robot structure has an  error in seismic calculation .
Could you please help me to understand this result. For seismic loading in according with UBC97 the program has calculated wrong values .Vx= 0 and Vy= 29.63 t !!!! . The Vx should be about 4.4 t .
Please use plain text.
Product Support
Artur.Kosakowski
Re: Seismic Result
08-18-2011 01:53 AM in reply to: MohammadZaman
MohammadZaman wrote:
Hi
Please make sure that you define large enough number of modes in the modal case to include vibrations in the X direction. For this model you should increase them from 3 to 6 as shown on the attached picture. In addition the main mode for the direction X should be the 4th rather than the 1st.
For the parameters as described above the value of Fx displayed for the diagram for buildings is 6.01T. If you look at the value of reactions you can see that it is 4.52T which is what you would expect. The difference between these values is explained in the answer for your previous post (see http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Seismic-Result/td-p/3101884).
Artur Kosakowski
Valued Contributor
MohammadZaman
Re: Seismic Result
08-18-2011 02:52 AM in reply to: Artur.Kosakowski
:smileywink:Thank you very much
