I'm used to generating automatic seismic and wind loads using ETABS. Ive been using ROBOT for almost 6 month but haven't had to generate seismic loads yet. I'm trying to do that based on UBC 97 but doesn't seem to work out. Can someone walk me through the process in a step by step manner including how to automatically generate code combinations.
Solved by Rafal.Gaweda. Go to Solution.
Hi
File attached.
Thanks a lot. I really found the information and the model helpful. How about creating automatic cominations. Do you have any word file explaining that procedure. Relations and all. I would really Appreciate it.
Start from this page:
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-541084D4-0E13-485A-8AE6-43D42DBE251-592.htm
Explanations here:
