Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Seismic load cases in combinations
3 REPLIES 3
bjornhgr
633 Views, 3 Replies
I have defined several load cases including seismic ones. When making automatic combinations the first time, all went well. However, after sending to Revit for a few ajustments and updating back to Robot, the seismic cases are no longer included in combinations. Why could this be?
Thanks!
3 REPLIES 3
Rafal.Gaweda
in reply to: bjornhgr
Hi
Any chance to upload the files or send them to us?
On my test model everything works fine.
Rafal Gaweda
bjornhgr
in reply to: Rafal.Gaweda
The file is pretty huge, so I 'm not sure sending is easily accomplished. I've managed to include them by redefining the seismic cases, which is not a big problem. I was just wondering if there was some kind of "thing" with seismic cases that I didn't know about.
Did you also try the back-and-forth-to-Revit part?
Rafal.Gaweda
I have checked manual combinations but in case of automatic comobinations the relations are misssing:
Set them again as shown below
or generate manual combinations basing on automatic combination generator (of course set \ check relation first):
Rafal Gaweda
