Discussion Groups
Robot Structural Analysis
Valued Contributor
3 Kudos
Seismic load cases in combinations
413 Views, 3 Replies
12-12-2011 01:09 AM
I have defined several load cases including seismic ones. When making automatic combinations the first time, all went well. However, after sending to Revit for a few ajustments and updating back to Robot, the seismic cases are no longer included in combinations. Why could this be?
Thanks!
Product Support
1,305 Kudos
Re: Seismic load cases in combinations
12-12-2011 01:32 AM in reply to: bjornhgr
Hi
Any chance to upload the files or send them to us?
On my test model everything works fine.
Rafal Gaweda
Valued Contributor
3 Kudos
12-12-2011 01:36 AM in reply to: Rafal.Gaweda
The file is pretty huge, so I 'm not sure sending is easily accomplished. I've managed to include them by redefining the seismic cases, which is not a big problem. I was just wondering if there was some kind of "thing" with seismic cases that I didn't know about.
Did you also try the back-and-forth-to-Revit part?
Product Support
1,305 Kudos
12-12-2011 01:52 AM in reply to: bjornhgr
I have checked manual combinations but in case of automatic comobinations the relations are misssing:
Set them again as shown below
or generate manual combinations basing on automatic combination generator (of course set \ check relation first):
Rafal Gaweda
