Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
afellows
372 Views, 4 Replies
Seismic Info
When I enter values for seismic design such as: S1, Ss, R, and I, Robot calculates values for Fv, Fa, Sd, Sds that are slightly lower than the values I calculated by hand even though we are both using the same building code calculation methods from ASCE.  Why is this so?
Thank you,
4 REPLIES 4
Artur.Kosakowski
in reply to: afellows
I think we should be proud that we are expected to provide the answer on the detailed question about the reason for the difference in values not knowing not only these values but the parameters for which they were calculated but I'm afraid this is not going to be possible Smiley Happy
To investigate this issue we need both your hand calcs and the corresponding Robot file with the model.
Artur Kosakowski
afellows
in reply to: Artur.Kosakowski
Attached are the differences in calculations...
afellows
I am not sure how to send the robot file, so hopefully this shows the parameters you are looking for.
Artur.Kosakowski
Just attach it in the same way as you did with the pdf file. If the size is what you are concerned about then select rtd without results as the type of the file in the Save as dialog and give it a new name. Then compress it.
Artur Kosakowski
