When i define seismic analysis type (equivalent lateral force method) , i want to define eccenticities in +X , -X direction with eccentriciies e=+5% & e=-5%
RSA should give me 4 cases :
1- +X with e = +5%
2- +X with e = -5%
1- -X with e = +5%
2- -X with e = -5%
but after determining the parameters of this , RSA defines also Y-direction .
This is shown in the screenshot , please see the cas name " ECC X-direction Y " , i only define x-direction !
Solved by dimogrec. Go to Solution.
Mohammed, click on "Directions and Combinations" tab (it's over the "Definition of eccentrities" see left part of your image.) and change Direction Y from 1 to 0.
Thank you for reply , its ok .
In my Egyptian code , i should define Direction of forces with e = 5% and also -5 % in diection +X and also -X , then i have 4 cases for X-Direction and also 4 for Y-Direction !
do i have to define seismic analysis 4 times ? or there is a method to define all cases for once ?
thanks in advance .
In my previous answer I thought you needed only seismic force in X direction. (That's why I wrote you to set 0 value at Y direction)
In your image you have set ecc only in X direction, so Robot generates X and Y seismic cases with ecc in X (+X and -X)
If you set also eccentricity Y you will have all the seismic cases with their eccentricity by once (10 in total. 2 of them without eccentricity (seismic X , seismicY) and 8 with eccentricity)
Now I'm not familiar with your code,so I don't know if you have to combine them (for example SeismicX+0.3SeismicY+...)...
