Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Seismic analysis floor definition
2 REPLIES 2
348 Views, 2 Replies
In the attached model, I have defined the floors and roof as rigid diaphragm in order to transfer the seismic force to seismic force resisting systems. But why are the column base reactions all the same under gravity load? It doesn't seem right. the corner column and edge column reaction should be smaller than middle columns.
Peijing
2 REPLIES 2
Rafal.Gaweda
This is not real situation. These diaphragms makes your model to behave like a full solid body cantilever column.
You should use Shell calculation model of Slab Flexible Diaphragm model or such model:
Rafal Gaweda
in reply to: Rafal.Gaweda
Thanks, I have defined a new slab type as you described. The result is very good. So for regular building with concrete floor and metal deck roof we should consider node connection as flexible stiffening in XY.
