Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Orchard_height
1577 Views, 3 Replies
Seimic data input
Currently I am working on a Canadian pump station design. I just want to know how to input seismic information based on NBC-2005, and local site soil parameters. The Robot I am working with is Robot Structural Analysis Professional 2011. Thanks
3 REPLIES 3
Bauskas
in reply to: Orchard_height
I see that Robot does not have the code you specified embedded.
Your option is to perfrom spectral analysis based on your code requirements, using raw response spectra from the code.
If you set your Preferences as Canadian this code will be set as the default automatically. Otherwise you can easily add it to the current list of the codes and set as the default one in the way shown on the attached picture. Hope this helps.
Artur Kosakowski
Bauskas
in reply to: Artur.Kosakowski
Yep, my fault. It shows the NBC code if switched to the Canadian settings
