Discussion Groups
Robot Structural Analysis
Distinguished Contributor
Jummybear
Sectorial moment of inertia
1647 Views, 6 Replies
05-18-2012 03:53 AM
Hi guys!
Is it possible in robot to calculate section sectorial moment of inertia in section defenition module? I didnt find it, probably was looking in wrong place or its not possible?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Sectorial moment of inertia
05-18-2012 04:01 AM in reply to: Jummybear
Yes, providing you define a section as a thin walled one.
Artur Kosakowski
Jummybear
05-18-2012 04:17 AM in reply to: Artur.Kosakowski
Ok, but if i want to get sectorial moment of inertia of some section from database? I cant define it like thin walled section... Or i should redraw section by hand te get that moment? Looks like not very logical way :smileyhappy:
Product Support
Rafal.Gaweda
05-18-2012 04:36 AM in reply to: Jummybear
Why illogical? Robot does not use iomega for some families so there is no such data for them.
Rafal Gaweda
Jummybear
05-18-2012 04:59 AM in reply to: Rafal.Gaweda
Really? And what about laterial buckling controll? It and Iw showld be taken into cansideration
Product Support
Rafal.Gaweda
05-18-2012 05:14 AM in reply to: Jummybear
Example, for IPE
Rafal Gaweda
Product Support
Artur.Kosakowski
05-18-2012 05:44 AM in reply to: Jummybear
For steel design module this value is generally calculated according to the provisions (formulas) from the code itself (the selection of the formula to be used is governed by a section symbol assigned to a particular section). Mind that LTB is checked only for selected section types (again this is governed by section symbol). The value from the database is used only when the steel design code itself doesn't provide the necessary formulas.
Artur Kosakowski
