Discussion Groups
Robot Structural Analysis
Active Contributor
Dirgs
Section Definition Analysis
330 Views, 5 Replies
12-18-2012 10:04 AM
Hi!
I get this result properties while using section definition module to analyze the section on following picture.
SD2.PNGDoes anyone knows how elastic flexural modulus get higher than the plastic flexural modulus??!...
Dirgs
Please use plain text.
Product Support
Rafal.Gaweda
Re: Section Definition Analysis
12-19-2012 12:51 AM in reply to: Dirgs
Send us sec file to check.
Rafal Gaweda
Active Contributor
Dirgs
12-19-2012 01:27 AM in reply to: Dirgs
Here it is :smileywink:
Product Support
Rafal.Gaweda
12-19-2012 03:52 AM in reply to: Dirgs
This section should be calculated rather as thin walled section - 0,5cm thickness on some parts comparing to ~6m length.
Algorithms must be checked by developers :-(
Rafal Gaweda
Product Support
Rafal.Gaweda
12-19-2012 05:30 AM in reply to: Rafal.Gaweda
If you have please send us dxf file with this section.
Rafal Gaweda
Active Contributor
Dirgs
12-19-2012 06:38 AM in reply to: Rafal.Gaweda
No problem. Hope it helps to improve the Section Module, seems there have not been major improvemens for for quite some time.
