Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Section builder
17 REPLIES 17
Message 1 of 18
mgaafar
2110 Views, 17 Replies
Section builder
    I had complex section so I imported the section from CAD as Dxf and added the section to used database. when I ran the analysis, RSA gave a msg saying that torsional constant IX=0 and a small value will be assumed. so when I opened the saved section I found that I had not selected the Torsion option so I did, but it did not save it back to the user database, So I opened the user database and added the values manually and saved.
now the IX still reads zero when I right click the member and see the properties. how can I refresh or let RSA update the user defined values?
also why RSA does not calculate the wraping constant?
17 REPLIES 17
Message 2 of 18
Rafal.Gaweda
in reply to: mgaafar
Send us sec file.
Rafal Gaweda
Message 3 of 18
mgaafar
in reply to: Rafal.Gaweda
Please find attached snap shots of the model, the model, the section file and the user database file.
in summary of what I need:
1- i am not sure how to update/refresh section properties of a section if I decide to change the property in the section (.sec) file and re-save it in the user defined database. currently I have to delete the existing section and re-save it to the database.
2-why when I resave the section to the database and re-insert the section in the model it does not update its properties and retain the old property?
Message 4 of 18
aruser
I have also had that issue with other section properties that I entered or changed them manually in the section database.
Try to re-add that section in the section box. You should see a message that says that this section already exists an so on...
Message 5 of 18
Artur.Kosakowski
Imagine that I edited the IPE100 section and I saved it in my user section database and I used it in the model. Then I sent you my model and you want to edit the model using the standard IPE100 section tehrefore you load it from the database after opening my file. Would you like to have my IPE100 replaced?
This is still possible but requires user's 'confirmation':
1. Select all bars with 'my' IPE100 section
2. Change their section to any other (e.g. IPE200)
3. Delete 'my' IPE100 section label from the list in the Sections dialog
4. Add standard IPE100 from the database
5. Replace IPE200 with IPE100
Artur Kosakowski
Message 6 of 18
Rafal.Gaweda
Then save it to database
Rafal Gaweda
Message 7 of 18
mgaafar
Rafal,
         Thanks, I know that this will solve the torsion constant calculations but my problem that when I save it in the database it does not update the section in the model, but it seems that I will have to rename the section and reinsert it in the model.
by the way does the section builder calculates the wraping constant?
Message 8 of 18
Rafal.Gaweda
take a look at message 5 above
Rafal Gaweda
Message 9 of 18
Rafal.Gaweda
Yes, for thin walled sections.
So you can create section as thin walled, calculate, then, if you need, you can convert it to thick walled section.
Rafal Gaweda
Message 10 of 18
aruser
How would be the way to to this Rafal?
Message 11 of 18
Rafal.Gaweda
in reply to: aruser
Look below
Rafal Gaweda
Message 12 of 18
I put from a Cad a Z section. How to read a wraping constant  from "Result" ?
Regards
Message 13 of 18
Rafal.Gaweda
Message 14 of 18
I have a doubt if in my Principal System is wraping constant.
Could check my ad?
Message 15 of 18
Rafal.Gaweda
This section is defined as a thick walled, not thin walled section.
eThin walled section results Example below
Start Thin walled section, import only centerline of section, then assign \ set correct thickness
Rafal Gaweda
Message 16 of 18
Thank you very much. This works.
Message 17 of 18
HELP !
How to make a new section (in Section Builder) in order to create variable inertia bars ?
(Impossible since the creation of the bar in Geometry tab)
Message 18 of 18
Rafal.Gaweda
