Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
bjornhgr
1606 Views, 1 Reply
Second order effects
Is there a way to see the second order share of forces when doing a non-linear analysis?
1 REPLY 1
Pawel.Pulak
in reply to: bjornhgr
The easiest way is to define 2 analogous load cases - one linear and another with second order effects.  Second order effects are visible  when comparing results for them.
Another possibility is to activate for non-linear load cases to save results after each load increment. Using these results the advanced diagrams can be displayed showing for instance force-displacement relations when incrementing the load. Increasing the number of load increments results in improving quality ("smoothing") or these diagrams.
See the attached screen capture showing what to modify and the example of diagram.
If this post answer your question please click "Accept as Solution".
It will help everyone to find answer more quickly!
Best regards,
Pawel Pulak
Technical Account Specialist
Tags (1)
