screen Capture missing Legend values for panels Maps results in ARSA 2012
1 REPLY 1
224 Views, 1 Reply
Hi
I am using windows 7 pro 64 bits with 64 bits (i7 processor).
When I try to take a screen capture using the PNG format of the Maps results  for panels in the ARSA profeesional 2012 the legend of values is not displayed in the printout. This problem occurs only in the ARSA 2012 (it is OK in ARSA 2011).
Can you have a solution for the problem .
Thank you very much
Wassim.
1 REPLY 1
Rafal.Gaweda
We will check it.
But if you do not use opening map in new window the scale will be properly captured.
Rafal Gaweda
