Shell Model will not Mesh
I have a simple Robot model (attached) that hangs up and runs out of memory when it tries to mesh.
(I am running Robot Structural Analysis Professional 2013 version 6.1 with the latest service packs on Windows 7 with service pack 1, 64 bit.)
Solved by t.sautierr. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
Thank you. What I modeled was only a million times larger than the anchor plate I intended to model. Heh, heh.
