In RSAPro 2013 the structure verification procedure keeps giving the "Duplicated load case label" warning. It seems that the automated numbering for the load type labels is not updating itself properly. In previous versions, I never changed this label manualy. If one creates a dead load, the software gives it a label, say "DL1". If I try to create a different dead load, the label does not update to "DL2" for the new load case - as it did in previous versions. Please advise on what is the correct procedure for avoiding the "Duplicated load case label" warning without having to manually change the labe id.
You can ignore this or change Label in Loads table \ Cases tab.
If you do use RC Footing Design module to design foundation for supporting node in model you can see them in calculation note in combination definition
i do have the same problem too, in RSA2014(!),and not only in one model, but also in all my new models from now on,. Although I realise the low importance of this, it is still annoying and I would like to extiguish it. Any support or ideas?
