In RSAPro 2012 steel design for ANSI/AISC 360-05; when trying to define the Cb parameter for "Lateral Buckling", the window for selecting the Parameter Cb does not pop-up (see attached file). Is this a software problem or am I missing a design step?
Thank you for indicating this issue. We will investigate it.
Please download and install SP3 for Robot 2012. Mind to select the correct version of the SP (Professional or Standard version as well as 32 or 64-bit OS).
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
