I am trying to open a dxf file in shell model but iRSA keeps crashing after I click OK in "Parameters of loading DXF/IGES- format files" dialogue box.
I have RSA Professional 2013 and it is up to date as the attached image shows
Also, dxf file is attached
I can't see any problem with doing that. I'm attaching the rtd file.
For some reason , it is not working on my PC. I guess I won't be able to use this feature 🙂
Try to unmark the indicated check box
Does it make any difference?
If not, send the crash report and let me know what email address you entered in the form so that I can find it please. Thank you.
I have already tried that but it did not work
As for the report, my e-mail address is msmars@gmail.com
Thank you ,
Are you able to open this dxf file in AutoCAD (if installed) on the same computer?
