Discussion Groups
Robot Structural Analysis
Active Contributor
0 Kudos
RSA API with Python
406 Views, 4 Replies
01-28-2013 04:58 AM
Is it possible to use the RSA API with Python ?
Guillaume
Product Support
1,305 Kudos
Re: RSA API with Python
01-28-2013 05:45 AM in reply to: guillaumeniel
Most likely yes (Python supports COM as far as I can see from google).
Rafal Gaweda
Active Contributor
0 Kudos
01-29-2013 08:36 AM in reply to: Rafal.Gaweda
I tried to import robotOM library with Python, but it looks like the library file as to be a .py file, not a .dll file. Does such a file already exist ? If not, how can I convert the Interop.RobotOM.dll file to a .py file ?
Product Support
1,305 Kudos
01-29-2013 08:39 AM in reply to: guillaumeniel
Sorry , I do not know.
Rafal Gaweda
Active Contributor
0 Kudos
01-31-2013 01:57 PM in reply to: Rafal.Gaweda
I found the syntax to import and use the API with Python :
import clr
clr.AddReferenceToFileAndPath("C:\...\Interop.RobotOM.dll")
import RobotOM as rbt
Then you can call RSA classes as follow :
Robot = rbt.RobotApplication
etc...
It may be usefull for Grasshopper users...
