Hi, I noticed whenever I click on the Job Prefernece > Design Codes > Loads
I get a message "The Parameter is incorrect" and the "Code Combinations" tab is empty.
This happens for all files and not particular file.
Solved by Artur.Kosakowski. Go to Solution.
Try to rename/delete your CfgUsr folder.
Aurther, I tried both renaming once and deleting and the problem still exist
I also uninstalled all previous versions of RSA and still problem exists!
What happens when you press on the red star button in Job Preferences?
Is it the same when you open Preferences and change the Regional seeings from Canadian (which I assume you have selected) to e.g. US or Eurocode?
Thanks Artur, when I reset the job preference by pressing the red star the error message disappeared.
