RSA 2015 Bug code combination
4 REPLIES 4
mgaafar
361 Views, 4 Replies
Hi, I noticed whenever I click on the Job Prefernece > Design Codes > Loads
I get a message "The Parameter is incorrect" and the "Code Combinations" tab is empty.
This happens for all files and not particular file.
4 REPLIES 4
Artur.Kosakowski
in reply to: mgaafar
Try to rename/delete your CfgUsr folder.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
mgaafar
in reply to: Artur.Kosakowski
Aurther, I tried both renaming once and deleting and the problem still exist
I also uninstalled all previous versions of RSA and still problem exists!
Artur.Kosakowski
What happens when you press on the red star button in Job Preferences?
Is it the same when you open Preferences and change the Regional seeings from Canadian (which I assume you have selected) to e.g. US or Eurocode?
Artur Kosakowski
mgaafar
Thanks Artur, when I reset the job preference by pressing the red star the error message disappeared.
