RSA 2014: Tolerance of structure model generation
6 REPLIES 6
Romanich
1203 Views, 6 Replies
Please see this video http://screencast.com/t/88kXBNWd
I clearly understand, that this situation is "synthetic" but it is abnormal, that Robot changes the object model instead of only the calculation model.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
6 REPLIES 6
Artur.Kosakowski
in reply to: Romanich
Thank you for showing us this situation. We will investigate it.
Artur Kosakowski
in reply to: Artur.Kosakowski
Romanich,
Is this the same as the problem I refer to here?:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Instability-type-3/m-p/3556848#M6447
I think this is a problem for a long time, not just 2014 version?
Tony
t.sautierr
idea 1 :
the tolerance is the one for model generation which includes meshing (if it is not frozen).
Do you have the same problem if the mesh is frozen before generating the model?
Idea 2 :
doesn't seem the geometry is changed (contour is the same but mesh goes beyond it) but calculation model doesn't fit I agree ... same problem if you change Coons to Delaunay or vice versa?
Idea 3 : the problem seems to occurs when you accuracy is close to the max size set for the FE, same problem if you set tolerance to 100mm instead of 500mm (your FE size) ?
Rafal.Gaweda
in reply to: t.sautierr
1. Of course tolerance should not touch panel geometry - it is being investigated
2. Problem in general is artificial - tolerances of 1 or 2 or 3 mm should be used in real life
Rafal Gaweda
Improved in Robot 2015.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Romanich
Hi @Artur.Kosakowski,
In Robot 2018 and 2019 the problem arose again.
Roman Zhelezniak
