Discussion Groups
Robot Structural Analysis
Active Member
alfredmx
Accepted Solution
RSA 2012 Steel Design Error
247 Views, 4 Replies
01-18-2012 11:16 AM
I'm using ASD 9th edition to check beam box sections. Depth of beam is 110cm and webs are 1.3 thick. According to section F4-2, allowable stress will be lower than 0.4Fy. I remember this was an issue on previous versions and was later fixed for I beams, however for box beams the program still checks against 0.4Fy.
Please use plain text.
Product Support
Artur.Kosakowski
Re: RSA 2012 Steel Design Error
01-18-2012 11:56 PM in reply to: alfredmx
Please attach the rtd file with the test model you made and indicate on the results dialog or the calculation note the verification that you think is done incorrectly. Thank you.
Artur Kosakowski
Active Member
alfredmx
01-19-2012 07:50 AM in reply to: Artur.Kosakowski
Hello Artur,
Please look at attached file. It contains note from RSA 2012 and hand calculations.
Product Support
Artur.Kosakowski
01-20-2012 02:10 AM in reply to: alfredmx
The code you selected in Job Preferences is the old version where implementation of this shear verification procedure in Robot is limited to H and C sections. Please use the new version of the code instead as shown on the attached picture.
Artur Kosakowski
Active Member
alfredmx
01-20-2012 07:44 AM in reply to: Artur.Kosakowski
Hello Artur,
Thanks a lot for your help.
