RSA 2012 Steel Design Error
4 REPLIES 4
alfredmx
423 Views, 4 Replies
I'm using ASD 9th edition to check beam box sections. Depth of beam is 110cm and webs are 1.3 thick. According to section F4-2, allowable stress will be lower than 0.4Fy. I remember this was an issue on previous versions and was later fixed for I beams, however for box beams the program still checks against 0.4Fy.
4 REPLIES 4
Artur.Kosakowski
in reply to: alfredmx
Please attach the rtd file with the test model you made and indicate on the results dialog or the calculation note the verification that you think is done incorrectly. Thank you.
Artur Kosakowski
alfredmx
in reply to: Artur.Kosakowski
Hello Artur,
Please look at attached file. It contains note from RSA 2012 and hand calculations.
Artur.Kosakowski
The code you selected in Job Preferences is the old version where implementation of this shear verification procedure in Robot is limited to H and C sections. Please use the new version of the code instead as shown on the attached picture.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
alfredmx
Hello Artur,
Thanks a lot for your help.
