Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
RSA 2012 - PROBLEM WHILE CREATING DEPLOYMENT CONFIGURATION
2 REPLIES 2
admin_biep
351 Views, 2 Replies
Hi everybody,
I'm having trouble while creating a deployment configuration. I'd like to add the SDK component to my configuration.
When in "Installation type" I choose "Custom" there is no "SDK" proposition, so i choose "Standard"
Then in the "Additionnal Files" field I choose "Addd Folder" or "Add Drive" (the result is the same), i choose "browse" and I go taking the" E:/x86/Tools/RSASDK/RSA_SDK.exe" file in the main folder (For a 32 bits installation)
I create the file with the ".lnk" extension, and when I lauch it, the setup installation stops ans shut down suddenly.
Does anyone have this problem? Does anyone have a solution?
Thanks.
2 REPLIES 2
Rafal.Gaweda
in reply to: admin_biep
Truly saying nobody has ever tried SDK installation in deployment.
SDK in unpacked (just unzip it) version:
ttp://www.megaupload.com/?d=XM699PPN
Rafal Gaweda
admin_biep
in reply to: Rafal.Gaweda
Thank you for the link.
I downloaded it but that doesn't solve my problem because when i'm in the "Additionnal Files" field and I choose "Addd Folder" or "Add Drive" (the result is the same) then i choose "browse" I can only pick a file and not a folder.
However, i have the same problem with Autocad.
So my question is: How to add plugins or programs while creating a deployment configuration? Is it possible to add an executable file like "whatever.exe" and it will do the installation?
Thanks for yout  help.
