Discussion Groups
Robot Structural Analysis
Member
PrRodriguez
RSA 2012 AND WINDOWS XP HOME 2002
122 Views, 3 Replies
12-26-2011 01:56 AM
I cannot install RSA 2012 in the pc and no messages appear when I try to install (set up does not open any window). The OS is Windows XP Home 2002.
Supposedly, Windows XP home with SP2 or later are supported. Am I right?
Could you give me any recommendation?
Thanks in advance
Please use plain text.
Product Support
Artur.Kosakowski
Re: RSA 2012 AND WINDOWS XP HOME 2002
12-27-2011 11:39 PM in reply to: PrRodriguez
There should be no issue with installing Robot on XP. What is the source of the installation (DVD, download from the web etc.) and what is the file you try to run exactly?
Artur Kosakowski
Member
PrRodriguez
12-28-2011 01:03 AM in reply to: PrRodriguez
It is from dvd and the OS seems not to recognize the set up file because do not open any window in the installation process. It could be a problem not to have installed any Windows servicepack?
Product Support
Artur.Kosakowski
12-28-2011 01:15 AM in reply to: PrRodriguez
Please make sure you run the right file (make sure that you have the file extensions displayed in the file browser). If this is not the case try to copy the installation on your local drive and run it from there.
Artur Kosakowski
