ROBOT / VBA / API - Structure rotation
7 REPLIES 7
Message 1 of 8
ve_75
631 Views, 7 Replies
I'm looking for making an entire rotation of my structure.
I think I have to define the point of rotation, the axis of rotation, and the angle of the rotation.
After looking in the guide, I found this, but it doesn't work for the moment:
Sub Entire_Structure_Rotation
     Dim Robot as New Application
     '1st step: Entire Structure Selection
     robot.Project.structure.Objects.GetAll 'or something like that
     '2nd step: Transformation: Rotation
     Dim structure_rotation As RobotObjOperRotation
     structure_rotation.AxsP1 = ??                             'don't know what to write
     structure_rotation.AxsP2 = ??                             'don't know what to write
     structure_rotation.Type = I_OOT_ROTATE      'I think it's this command
    End sub
Is it possible to have an example for a rotation of 45 degrees from the point (0,0,0) and around the Z axis?
Thanks for answering,
VE
7 REPLIES 7
Message 2 of 8
Rafal.Gaweda
in reply to: ve_75
From documentation:
SelRotate ( see page 990) Function performs the operation of rotation on the current selection. .
Use :
Robot.Project.Structure.Edit.SelRotate.........
Rafal Gaweda
Message 3 of 8
ve_75
in reply to: Rafal.Gaweda
Thank you for your answer, i didn't see this command.
I'm trying to make a global selection (all cases, all structure, all nodes, ..., everything)
I managed to select the whole structure (nodes and panels) but not for all cases.
Is it possible to add some elements to the following code please and select all cases of the model please?
     Sub entire_structure_rotation()
     Dim robot As New RobotApplication
     Set robot = New RobotApplication
     robot.Project.structure.Selections.Get(I_OT_OBJECT).FromText ("1A1000")      'Seems OK
     robot.Project.structure.Selections.Get(I_OT_CASE).FromText ("1A1000")           'Seems not to work
      robot.Project.structure.Selections.Get(I_OT_NODE).FromText ("1A100000")     'Seems OK
     '2nd step: Entire Structure Rotation
     Dim transformation As IRobotStructureEditTools
     Set transformation = robot.Project.structure.Edit
     transformation.SelRotate 0, 0, 0, 0, 0, 1, 50, I_TO_MOVE, 1                                       'Seems OK
     End sub
Thank you,
VE
Message 4 of 8
Rafal.Gaweda
in reply to: ve_75
What for?
Loads are copied  \ moved with objects which they are assigned to.
Rafal Gaweda
Message 5 of 8
ve_75
In fact the code I gave you doesn't select cases... I don't understand why....
Do you have an idea?
VE
Message 6 of 8
Rafal.Gaweda
in reply to: ve_75
Rafal Gaweda
Message 7 of 8
ve_75
In fact the problem comes from the specific type of loading case.
The rotation works with uniform loadings while it doesn't work with loadings defined by a "contour".
Do you have a solution to move all type of loadings at the time?
You can do the test with the enclosed file and the following code:
      robot.Project.structure.Selections.Get(I_OT_OBJECT).FromText ("1A100000")
     robot.Project.ViewMngr.Refresh
     transformation.SelRotate 0, 0, 0, 0, 0, 1, -50, I_TO_MOVE, 1
     End Sub
Message 8 of 8
Rafal.Gaweda
in reply to: ve_75
Load type, not case.
It does not work in Robot either.
Any contour load can not be copied moved rotated.
Rafal Gaweda
