Is there any way to change automatic numbers of cases generated while calculating moving loads through API and VBA?
I mean the number of case+ and case-. In fact it takes the first "freenumber" it can (like the API command getfreenumber).
It possible manually (modify in cases table), but i'd like to do it automatically.
For example: Moving load case number = 800
Numbers generated after calculation: 2 and 3.
Numbers desirated after calculation: 801 and 802 (by logic)
You'll find enclosed an illustration.
Thanks for answering.
VE
No.
