Using link between RSA and RVT , can i convert structure in RSA (rtd) to Revit file ?
Solved by Rafal.Gaweda. Go to Solution.
In case of products family 2015 you can transfer model directly or thru smxx file.
In case of products family 2014 you can transfer model only directly.
No way to convert rtd to rvt.
See:
http://forums.autodesk.com/t5/robot-structural-analysis/revit-to-robot/td-p/3812616
Ok , i know how to export from Revit to Robot but , i thought that i can export .rtd file to .rvt file .
Thank you for your time .
In v.2014 you can "Update" empty Revit model (being in Revit) with Robot model and save rvt file.
Using 2015 on both , will panel openings be transferred from Robot to Revit??
What about Robot structural axes??
thx
Rafael Medeiros
Unfortunately not 😞
