Robot Steel API - Member definition parameters
11 REPLIES 11
Message 1 of 12
samuel.pereira
1822 Views, 11 Replies
I'm trying to define members parameters, using Robot Steel API, to design a bar structure steel with EN1993-1.
I have seen the document "Robot API Steel Design" but I can’t do it. It’s possible provide a complete example to "Visual Basic -Microsoft Excel" for a “Bar” type?
11 REPLIES 11
Message 2 of 12
Look closer at paragraphs 4.4.1 and 4.4.2 in mentioned doc.
Examlpe below
Set all \ required RDimMembParams in place where you cae see commented dots in code below
Dim RobApp As RobotApplication
Set RobApp = New RobotApplication
    RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "ENV 1993-1:1992"
    Dim RLabel As IRobotLabel
    Dim RdimLabelData  As IRDimMembDefData
    Dim RDimMembParams As IRDimMembParamsEC3
        Set RLabel = RobApp.Project.Structure.Labels.Create(I_LT_MEMBER_TYPE, "My Label")
        Set RdimLabelData = RLabel.Data
        RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Y, 100
        RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Z, 200
        RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_X, 300
        RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_Y, 400
        Set RDimMembParams = RdimLabelData.CodeParams
        RDimMembParams.BuckLengthCoeffY = 10
        RdimLabelData.CodeParams = RDimMembParams
        RobApp.Project.Structure.Labels.Store RLabel
Rafal Gaweda
Message 3 of 12
Thank you!
Message 4 of 12
When I run the Macro in Excel, it return an error:
Run-time '13'
Type mismatch
It occurs on line:
Annex image with the error.
Thank you!
Message 5 of 12
Wrong Params.
    RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "ENV 1993-1:2005"
    Dim RDimMembParams As IRDimMembParamsE32
Rafal Gaweda
Message 6 of 12
Ok! Already works! Thank you!
Message 7 of 12
At the moment, I have defined the member type. What remains now is to assign the type of member to the respective bar, in other words, assign the type "My Label" to a bar 1 and 2, for example. How do this? You can send an example?
Thank you.
Message 8 of 12
Like for all labels
for one \ given bar number
Dim Rbar As RobotBar
Dim BarCollection As RobotBarCollection
RobApp.Project.Structure.Bars.Get(bar_number).SetLabel I_LT_MEMBER_TYPE, "My Label"
'or
Set Rbar = RobApp.Project.Structure.Bars.Get(bar_number)
Rbar.SetLabel I_LT_MEMBER_TYPE, "My Label"
for bar collection
Set RobotBarCollection = .........
For i = 1 To BarCollection.Count
BarCollection.Get(i).SetLabel I_LT_MEMBER_TYPE, "My Label"
Next i
Rafal Gaweda
Message 9 of 12
in reply to: Rafal.Gaweda
Dear all,
I tried to implement the code below with the corrections made and wasn't able to do it.
An error appears in the line that sets Member Parameters :
Sub A_MemType()
        Set RLabel = RobApp.Project.Structure.labels.Create(I_LT_MEMBER_TYPE, "My Label")
        Set RdimLabelData = RLabel.data
        RobApp.Project.Structure.labels.Store RLabel
End Sub
 Thanks in advance.
Message 10 of 12
Artur.Kosakowski
Try:
Sub A_MemType()
           RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "EN 1993-1:2005/AC:2009" ‘ "ENV 1993-1:2005"
           Dim RDimMembCodeParams As Object ‘IRDimMembParamsE32
           RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Y, 100 RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Z, 200
           RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_X, 300 RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_Y, 400
           Set RDimMembCodeParams = RdimLabelData.CodeParams
           RDimMembCodeParams.BuckLengthCoeffY = 10
           RdimLabelData.CodeParams = RDimMembCodeParams
    End Sub
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 11 of 12
in reply to: Artur.Kosakowski
Thanks Arthur. It worked perfectly.
Message 12 of 12
Hello @Artur.Kosakowski,
how to translate  Dim RDimMembCodeParams As Object in C# ?
Thank you in advance,
Regards
Louis
