I'm trying to define members parameters, using Robot Steel API, to design a bar structure steel with EN1993-1.
I have seen the document "Robot API Steel Design" but I can’t do it. It’s possible provide a complete example to "Visual Basic -Microsoft Excel" for a “Bar” type?
Solved by Artur.Kosakowski. Go to Solution.
Look closer at paragraphs 4.4.1 and 4.4.2 in mentioned doc.
Examlpe below
Set all \ required RDimMembParams in place where you cae see commented dots in code below
Dim RobApp As RobotApplication Set RobApp = New RobotApplication RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "ENV 1993-1:1992" Dim RLabel As IRobotLabel Dim RdimLabelData As IRDimMembDefData Dim RDimMembParams As IRDimMembParamsEC3 Set RLabel = RobApp.Project.Structure.Labels.Create(I_LT_MEMBER_TYPE, "My Label") Set RdimLabelData = RLabel.Data RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Y, 100 RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Z, 200 RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_X, 300 RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_Y, 400 Set RDimMembParams = RdimLabelData.CodeParams RDimMembParams.BuckLengthCoeffY = 10 '...... RdimLabelData.CodeParams = RDimMembParams RobApp.Project.Structure.Labels.Store RLabel
When I run the Macro in Excel, it return an error:
Run-time '13'
Type mismatch
It occurs on line:
Annex image with the error.
Thank you!
Wrong Params.
RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "ENV 1993-1:2005" '..... Dim RDimMembParams As IRDimMembParamsE32
At the moment, I have defined the member type. What remains now is to assign the type of member to the respective bar, in other words, assign the type "My Label" to a bar 1 and 2, for example. How do this? You can send an example?
Thank you.
Like for all labels
for one \ given bar number
Dim Rbar As RobotBar Dim BarCollection As RobotBarCollection RobApp.Project.Structure.Bars.Get(bar_number).SetLabel I_LT_MEMBER_TYPE, "My Label" 'or Set Rbar = RobApp.Project.Structure.Bars.Get(bar_number) Rbar.SetLabel I_LT_MEMBER_TYPE, "My Label"
for bar collection
Set RobotBarCollection = ......... For i = 1 To BarCollection.Count BarCollection.Get(i).SetLabel I_LT_MEMBER_TYPE, "My Label" Next i
Dear all,
I tried to implement the code below with the corrections made and wasn't able to do it.
An error appears in the line that sets Member Parameters :
Sub A_MemType() Dim RobApp As RobotApplication Set RobApp = New RobotApplication RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "ENV 1993-1:2005" Dim RLabel As IRobotLabel Dim RdimLabelData As IRDimMembDefData Dim RDimMembParams As IRDimMembParamsE32 Set RLabel = RobApp.Project.Structure.labels.Create(I_LT_MEMBER_TYPE, "My Label") Set RdimLabelData = RLabel.data RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Y, 100 RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Z, 200 RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_X, 300 RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_Y, 400 Set RDimMembParams = RdimLabelData.CodeParams RDimMembParams.BuckLengthCoeffY = 10 '...... RdimLabelData.CodeParams = RDimMembParams RobApp.Project.Structure.labels.Store RLabel End Sub
Thanks in advance.
Try:
Sub A_MemType()
RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "EN 1993-1:2005/AC:2009" ‘ "ENV 1993-1:2005"
Dim RDimMembCodeParams As Object ‘IRDimMembParamsE32
Set RDimMembCodeParams = RdimLabelData.CodeParams
RDimMembCodeParams.BuckLengthCoeffY = 10
RdimLabelData.CodeParams = RDimMembCodeParams
End Sub
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Hello @Artur.Kosakowski,
how to translate Dim RDimMembCodeParams As Object in C# ?
Thank you in advance,
Regards
Louis
