Robot slow model for tapered section NTM forces
4 REPLIES 4
Mirko.Jurcevic
301 Views, 4 Replies
I have a model with about 250 manually generated combinations.
Model is very slow (it is not big, 1 story, 8x32m, only bar elements). But it is very very slow when I try to display NTM forces for console tapered bars.
Artur, Rafal, can anyone check it out, see PM.
Thanks!
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
4 REPLIES 4
Do you mean display of envelope?
Rafal Gaweda
Yes, envelope, I'm sorry for not mention it.
No matter, GSU or KGS groups (envelopes), same thing.
Mirko Jurcevic
Yes, it is like that because these are tapered sections
For standard sections diagram is displayed usually on 11 discrete points along calculation element but section stiffeness is known in each point and displacement \ internal forces are calculated by "formulas"
IN case of tapered sections diagram is displayed usually on 11 discrete points along calculation element but section stiffeness has to be calculated in each point and displacement \ internal forces are calculated by algorithm with some integrals so the time for this task must be significantly longer.
Rafal Gaweda
Maybe this should be prepared in advance so it doesn't take so much time.
But, ok, thank you. I thought it may be related with wrong modelling.
Mirko Jurcevic
