So i followed the instructions in the pdf to create & add a new RCDesign code to robot structural analysis but when i build it, it gives me that error "Error while creating robot registry key." so i tried to debug it with regsvr32.exe under sysWOW64 directory "I Have x64 Windows 8.1 Pro OS" It gave me the same error and i noticed that HRESULT hr value becomes 0x80040154 Class not registered I'am not a programmer i'am an engineer and i can't solve this "it's too complicated for me to solve specially the component object model and ATL" so i hope that someone help me with it.
i have attached photos of printcreens of the error
there was a similar problem on stackoverflow site and some one sugessted that __uuidof() returns IID not CLSID i don't know the difference i hope that someone could see this and tell me what to do about it here's the link :
http://stackoverflow.com/questions/19959950/com-error-class-not-registered-im-sure-it-is
Solved by Rafal.Gaweda. Go to Solution.
Thank you veryyyyy much I will send it to you but i didn't do any thing to it just copied and pasted the USERPROFILE and wizards folders to vs 2008 as indicated in the pdf, created a project, then built it. i use vs 2008 sp1 and i use the project template provided
See attached pdf how to set it properly in VS2008
Updated project here http://we.tl/DNZTj0EIKT
thank you very much now i understand i must call a x64 dll from x64 bit Program thank you once again
