Having Problem With Robot.
It switches Local Axis on it's own even I modified it. Tried Loading it up then after that It switches local axis on its own.
Had similar problems on other models done on other PC
I use RSAP 2014. I can't attach it here, or use the sharing sites since its blocked by our IT. Can I send it to your Yahoomail instead?
Is that possible? posting a link using yahoo mail?? hmmm i don't get your point. I don't have means to upload my file thru any of your recommend file uploaders since all are blocked here at our office...
I do not know how it is done by yahoo, I do not use it.
Check your mailbox, if not - try from home, if not 😞
Here is the link in my yahoo mailbox..
I don;t know if you can download it
https://us-mg5.mail.yahoo.com/neo/launch?.rand=28lld35t629nh#
@Rafal.Gaweda wrote:
I do not have any yahoo mail
Just post link here
but you said, i can use yahoo mail then i'll post the link here for you to download and see the file... or you're sticking to the upload my file to 4shared, dropbox, etc., which is still blocked by our IT
Just post link herebut you said, i can use yahoo mail then i'll post the link here for you to download and see the file...
Bacause I did not know that yahoo links works like that.
But I also said : check your mailbox -> it seems you have emails also blocked because I have not seen any response from you.
I also said : upload it from home ...
So I suggest to go to subscription center and enter your case there unless it is also blocked on your side and you know password to it.
