Discussion Groups
Robot Structural Analysis
New Member
0 Kudos
Robot or Revit for Students
64 Views, 1 Replies
02-26-2014 08:37 AM
Hi everyone! I'm helping my teacher of “Structural Analysis I” and “Structural Analysis II” at my university and we are trying to make the students use the Autodesk programs so we have think that maybe they can check/control the results of the class exercises with Robot or Revit. We are talking about really basic stuff like geometric properties of a section and a low level of structural analysis.
Things like the one in the image that are very simple, the ABC of structural analysis and later we will also want to make then check more complex structures.
The problem is that in the first part of the curse they need to do some calculations without considering material or section of the structure and I don’t know how to do it in Robot or Revit, actually I don’t know if that’s even possible. The image shows a simple beam and a force in the middle, without any calculator we know that the reactions are only vertical but in the opposite direction of the force (F) and both of them are the half of the force (F/2) the point is that when things get more complicated they should check it with Robot and/or Revit but always that I use any of this program for real uses I use a material and a section and now I just don’t know how to consider just this.
Does anyone know how to do it?
Thanks!
Product Support
760 Kudos
Re: Robot or Revit for Students
02-26-2014 09:16 AM in reply to: fernan.cgf
Just assign the same material and section to all elements of a model (you have to assign them to be able to calculate a model in Robot).
Artur Kosakowski
