I would like to define a steel rectangular custom section (not hollow) with ROS, and then define a custom material for it (I am using fabric sections).
Here is my script, for a concrete section :
section.ShapeType = IRobotBarSectionShapeType.I_BSST_CONCR_BEAM_RECT
Dim concrete As RobotBarSectionConcreteData
concrete = section.concrete
concrete.SetValue(IRobotBarSectionConcreteDataValue.I_BSCDV_BEAM_B, 0.5)
concrete.SetValue(IRobotBarSectionConcreteDataValue.I_BSCDV_BEAM_H, 0.5)
What is the conversion for a steel section ? Do I only have to replace concrete by steel ? Also, how can I define the material for this section ?
Solved by Rafal.Gaweda. Go to Solution.
bouboutcpge wrote:
I need the syntax of the basic objects in steel design
Check this:
or a link to documentaion about it .
INstall SDK and look at Robot API SteelDesign.pdf or here:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Manual-Calculations-for-Steel-Design-using-A...
