Discussion Groups
Robot Structural Analysis
Member
anton.belyakov
Robot on 2 or more processor workstation
763 Views, 10 Replies
09-18-2012 01:55 AM
Hello! My company is working on increasing the speed of calculations in Robot. So the question is will the program work on 2 processor (not 2 core)  workstation and will it increase the performance of the programm? Thanks.
Please use plain text.
Product Support
Rafal.Gaweda
Re: Robot on 2 or more processor workstation
09-18-2012 02:11 AM in reply to: anton.belyakov
There is no difference if you use multi core processor or multi processor machine
Here is the document which operations are \ can be run on separate core \ processor
In some cases Robot can use multiple processors. For instance the
following operations in Robot are run as separate threads :
1/ FEM analysis
2/ calculations of theoretical reinforcement in plates
3/ calculations of theoretical reinforcement in bars
4/ each calculations of steel/aluminium/timber design
Each of these threads can use up to 100% of resources of one processor.
So for instance for FEM analysis the advantages of several
processors are not very significant (solver can use only one processor
except multithreaded solver)
but if you perform some other operations (like viewing, sorting tables,
analysing graphical views, selecting some objects, etc.) during analysis
Robot will be faster because solver will use one processor and second
processor will be used for these operations.
Similar situation concerns speed of Robot when performing operations 2/
3/ 4/.
Higher advantages can be obtained when performing simultaneously
operations 2/ 3/ 4/ - each of them can be performed by different
processor.
Moreover as concerns operation 4/ (steel/aluminium/timber design) user
can start several such calculations simultaneously with for instance
different list of members or groups and each of them can be performed by
different processor.
Rafal Gaweda
Member
anton.belyakov
09-18-2012 02:35 AM in reply to: Rafal.Gaweda
Thank you for such a detailed answer.
Active Member
lythetich
09-11-2013 08:30 PM in reply to: Rafal.Gaweda
i have just read your answers for this issues, but i have one questions for "Product Support", how long we can use GPU to caculate for "Robot, Revit" or processing some thing interdepand caculation for " Autodesk Product" ???
i have wait too long since the GPU workstation release by Nvidia.
we will very happiness for this ....
now,sleep... dreaming...working and waiting.
Product Support
Rafal.Gaweda
09-11-2013 11:22 PM in reply to: lythetich
I am afraid I do not understant.
CPU is used as long as required by program, sometimes a few seconds, sometimes minutes, hours, days. It depends on model size and type and number of cases to ba calculated.
Rafal Gaweda
Active Member
lythetich
09-12-2013 01:07 AM in reply to: Rafal.Gaweda
Dear,
in here, i taking about "caculation" is mean " Big and complex caculations".
for example: when i creating or copying some or more objects in "Autocad Structures Detailing", it will be re-caculate for all, but so strange, in the "Duo Core CPU and HDD normal" vs "Xeon CPU and SSD" not so diffrence. ( of couse two computers have a lot of difference at all )
And the issues in here, is not a Hardware fail.
comeback to the Autodesk Robot, it's still not so diffrence.
So, Why we don't make a change, Autodesk and Nvidia, sit together, and talking about this issues, and more issues to make something bigger, something faster, we have paid a lot of money per years to buy an Autodesk Product for what? Beause i believed Autodest can do anything we need.
Yes, i'm talking about GPU Computing Technology for Autodest Robot, and more Autodesk products.
Product Support
Rafal.Gaweda
09-12-2013 01:38 AM in reply to: lythetich
Send me model I can tell you how it works on our computers
Rafal Gaweda
Active Member
lythetich
09-13-2013 02:04 AM in reply to: Rafal.Gaweda
okie,
The first one:
Mainboard: Socket 775
CPU: core 2 dou E7800
RAM: 4GB bus 667
HDD 5400rpm
VGA: Intel
Windows XP 32bit SP 3
AutoCAD Structures Detailing 2012
The second:
Mainboard: socket 1155
CPU: Xeon E1230v3
RAM: 8GB bus 1600
HDD: SSD Kingston 120GB
VGA: Quadro 2000
Windows 7 Pro 64bit
AutoCAD Structural Detaing 2014
that is summary, please tell me something you want make to know about it.
Product Support
Rafal.Gaweda
09-13-2013 02:23 AM in reply to: lythetich
Rafal Gaweda
Active Member
lythetich
09-22-2013 04:36 AM in reply to: Rafal.Gaweda
sorry, i'm so stupid for "model" mean, so sorry,
but the model processing in my company is private, i can't send to you, or share it in the public,
but, there model is 50 floor building, so you can thinking, it's will be great. hi
