Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Robot member type definition by API
1 REPLY 1
aliyuaziz
1519 Views, 1 Reply
I'm trying the first simplest example in the getting started guide:
Sub Click_point()
Dim Robot As New RobotApplication
Robot.Project.New I_PT_FRAME_2D
Robot.Project.Structure.Nodes.Create 1, 0, 0, 0
Robot.Project.Structure.Nodes.Create 2, 3, 0, 0
Robot.Project.Structure.Bars.Create 1, 1, 2
Dim Label As RobotLabel
Set Label = Robot.Project.Structure.Labels.Create(I_LT_SUPPORT, "Support")
Dim SupportData As RobotNodeSupportData
Set SupportData = Label.Data
SupportData.UX = 1
SupportData.UY = 1
SupportData.UZ = 1
SupportData.RX = 0
SupportData.RY = 0
SupportData.RZ = 0
Robot.Project.Structure.Labels.Store Label
Robot.Project.Structure.Nodes.Get(1).SetLabel I_LT_SUPPORT, "Support"
Robot.Project.Structure.Nodes.Get(2).SetLabel I_LT_SUPPORT, "Support"
Set Label = Robot.Project.Structure.Labels.Create(I_LT_BAR_SECTION, "Beam50*50")
Dim section As RobotBarSectionData
Set section = Label.Data
section.ShapeType = I_BSST_CONCR_BEAM_RECT
Dim concrete As RobotBarSectionConcreteData
Set concrete = section.concrete
concrete.SetValue I_BSCDV_BEAM_B, 0.5
concrete.SetValue I_BSCDV_BEAM_H, 0.5
section.CalcNonstdGeometry
'Robot.Project.Structure.Bars.Create 1, 1, 2
Robot.Project.Structure.Bars.Get(1).SetLabel I_LT_BAR_SECTION, "Beam50*50"
Dim caseSW As RobotSimpleCase
Set caseSW = Robot.Project.Structure.Cases.CreateSimple(1, "SW", I_CN_PERMANENT, I_CAT_STATIC_LINEAR)
caseSW.Records.New I_LRT_DEAD
Dim LoadRec As RobotLoadRecord
Set LoadRec = caseSW.Records.Get(1)
LoadRec.SetValue I_DRV_Z, -1
LoadRec.SetValue I_DRV_ENTIRE_STRUCTURE, True
If Robot.Project.CalcEngine.Calculate = True Then
    MsgBox Robot.Project.Structure.Results.Bars.Forces.Value(1, 1, 0.5).MY
End If
Set Robot = Nothing
End Sub
 Which results in the bar created as a 'Simple bar' type. I would like to know how to create the bar as an RC beam type or how to change it after it has been created.
Thanks a lot.
Aliyu A. Aziz
1 REPLY 1
