Hi Rafal
Can you explain ( short video) how to model a flat slab with drop panel according to the pic below
Please check:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Drop-panel/m-p/4873916
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Column-head/m-p/3511404
Thanks Artur
But i did not get what i want
i hope you make a short video in order to all member can understant
Regards
Please check the attached document.
Thanks for help ,
In reality the top of both panels ( TH20 and TH30 ) must have one level , here is the problem , how to make top of both panels have same level as in parking building.
Regards
For out of the plane bending this is irrelevant (unless you have large in plane forces which is I'd say unlikely for a typical slab design).
Otherwise check:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Slab-Thickening/m-p/4311566#M14912
